05-01-2018 06:06
05-01-2018 06:06
What exactly is quick view? And do I need it on? Thanks.
05-01-2018 06:24
05-01-2018 06:24
Quick View is where the screen will turn on when you raise your wrist to look at it. You don't have to have it on but I find it very useful.
08-27-2018 05:12
08-27-2018 05:12
Quick view is **ahem**.
I have it set to off
And I also have the face turned off manually.
Everytime I move while trying to sleep the **ahem** brightens the room
08-30-2018 20:59
08-30-2018 20:59
I cannot get any Information to shop on my versa watch.
Best Answer10-03-2018 13:11
10-03-2018 13:11
This also happens to me, now more often than before.
I think its draining my battery life 😞
04-27-2019 08:10
04-27-2019 08:10
It would be nice if we were able to program the times we would like to have Quick View on. That way I could sleep with my watch on every night. It's a pain in the *ahem* to have to turn it off every night and back on in the morning.
07-24-2019 23:16
07-24-2019 23:16
They have given a small fix to this. When you go to your music options on the device swipe to the left and the option of screen wake is available. It is the same as quick view
Best Answer12-28-2019 09:31
12-28-2019 09:31
If you have Quick view on, when you raise your wrist the screen will turn on. However, if you have it off, the screen will only turn on with a tap or a button press!
P.S. The new sleep Mode (That you can turn on from the watch) automatically turns quick view off so the screen won’t come on while sleeping!
02-05-2021 05:10
02-05-2021 05:10
I used to have that problem too, but I currently use a Fitbit Versa 2 so I can make a schedule for something called night mode to automatically turn on at a certain time and turn off at a certain time. Night mode automatically turns off quick view when it’s on so the **ahem** won’t brighten the room.
