I'm not quite sure how this forum works for starting a new thread or seeking assistance. Apparently, there's no sub-topic that I can find. I have a Versa 2 that won't reliably charge. I have three chargers and everyone of them regardless of what they're plugged into won't charge. I keep getting 'Not enough power'. I KNOW that's not the case. After reading a thread (from 2018), it concluded it was the charger. No it's not! It's the watch. I've tried every cradle I have, using different and very powerful chargers to no avail. Any chance this topic has been addressed in the last 4 years? All of the chargers were working fine when the watch was new. But now that it's 2 years old, it won't charge and I get a silly message about power.
Best Answer@redjr This might not be the cure, but have you cleaned the charging contacts on the back of your Fitbit? And the pins on the charger? Use a very soft toothbrush with rubbing alcohol on the Fitbit. Use a cotton tipped applicator with alcohol on the charger and be very careful so you don’t push the pins in. I don’t get drenched in sweat very often. But the back of my tracker does get dirty.
