03-16-2019 08:03
03-16-2019 08:03
Hi, I accidently deleted by partially functioning Versa from my account and am trying/failing to reconnect it with my account. For a few days it has not recognized any Wi-Fi connections and now that is where I am stuck/prevented from reconnecting the Versa to my account. It gives me the Not Working? screen and I have done all of the trouble shooting that it recommends. HELP!
03-16-2019 09:00
03-16-2019 09:00
@Always4anna wifi is not needed to setup your Versa, I would try again and choose the shop wifi setup.
Since the tracker was setup there most likely isn't a firmeare update anyway.
Once we have the Versa setup we can then if needed setup the wifi.
03-16-2019 13:21 - edited 03-17-2019 08:34
@Rich_Laue Yes the device did reconnect (finally) with my mobile, but the Wi-Fi is still lost without options offered wirelessly or while connected to my computer to choose anything but "Try To Connect to Wi-Fi" which consistently fails 😞
03-19-2019 16:01
03-19-2019 16:01
03-19-2019 23:26
03-19-2019 23:26
@Always4anna look below and click on the help link, then your tracker model, from here you can download the user manual.
In short to restart the tracker press the left and lower right buttons
