Re: Versa can't connect to WiFi
My versa can’t connect to my wifi
2 REPLIES 2
Hello @kaynerob1 without any info im not sure how to help.
Is your WiFi 2.4ghz, 5.0 will not work.
Does your Versa find your WiFi? Where you able to put in the security code?
Did you get any errors?
Is the Versa plugged in and charging?
Thank you
Hi @kaynerob1 , could you give some more information about this problem? Which phone are you using, etc, etc. Regards kuzibri
