Re: Versa wont connect/sync to my Samsung Galaxy s7 edge
Similarly,  my Versa has not synced since May 14.
I have tried:
Restarting phone
Uninstalling/Reinstalling app; twice
Clear cache/Force stop/restarting
Powering off Versa
Bluetooth is connected
Other bluetooth items are off
Versa is charged
Wi-fi on my phone is on
*Wi-fi on versa does same thing as sync...spinning circle then stops.
6 REPLIES 6
First thing I would do is remove the Versa from the list of trusted Bluetooth devices.
Your Versa"a WiFi has nothing I do with syncing data.
Did this issue start after a phone update?
Have you tried with both cellular and WiFi with the phone? The versa itself will only sync through Bluetooth.
Same exact thing with mine.
Same with my Galaxy Note8.  Tried all the suggestions listed on this thread and in the community forum re: Android Pie 9.  Still not working.
Thank you, it just started working again after I ignored it for a while. Maybe there was just weird delay.
Same here. I factory reset,  forced stopped, cleared cashe, reinstalled,
Still nothing. It won't connect and it finds my Bluetooth then gives error messages and failure to update firmwear since the may 22 update.
