08-26-2019 18:37
08-26-2019 18:37
This morning my Versa recorded my first 2 flights of stairs and then it stopped. I probably have done 20 flights and still only slowing 2. Everything else seems to be working fine. I have reset it multiple times
08-26-2019 23:39
08-26-2019 23:39
Your versa tracks floors by detecting changes in air pressure through a small hole in the back of the tracker. If this becomes blocked in some way it can cause floor tracking to stop. Try gently cleaning it with, say, an old toothbrush or perhaps a can of compressed air.
08-27-2019 15:07
08-27-2019 15:07
08-27-2019 23:11
08-27-2019 23:11
All I can suggest is that you contact customer support. If they can't fix it they can check your warranty status and advise on your options. You can get to them via: contact.fitbit.com
08-28-2019 03:02
08-28-2019 03:02
08-31-2019 03:38
08-31-2019 03:38
I contacted Fitbit and haven't heard from them yet.
