07-26-2019 14:10 - last edited on 07-28-2019 15:14 by LiliyaFitbit
Purchased a versa lite for my daughter and the screen won’t clear or sync. Has a red x on the screen. Restarted and it’s still there.
Best Answer05-02-2020 18:59
05-02-2020 18:59
I’m having the same problem as everyone else. I have tried everything this post has offered. Still isn’t working. I have tryin for a few days. Please help!!
05-02-2020 20:20
05-02-2020 20:20
Best Answer05-03-2020 04:50
05-03-2020 04:50
05-03-2020 06:16
05-03-2020 06:16
05-03-2020 09:55
05-03-2020 09:55
I have done that with no help, this is the replacement one that I am having trouble with. This is the replacement one they send me and I cannot get it to work. It’s the one with the big red x. I believe there is a flaw in the design of the fitbit light. I thing they should be replacing all fitbit light. I even have a case file so what go is it, the stuff they told me to do has been done about 50 times already.
Best Answer05-03-2020 10:14
05-03-2020 10:14
Best Answer05-03-2020 10:17
05-03-2020 10:17
05-03-2020 10:31
05-03-2020 10:31
Best Answer05-03-2020 10:33
05-03-2020 10:33
This has not helped me, the problem is still there. My fitbit is just 3 months old
Best Answer05-03-2020 10:45
05-03-2020 10:45
Best Answer05-03-2020 10:53
05-03-2020 10:53
Best Answer05-03-2020 11:04
05-03-2020 11:04
Best Answer05-03-2020 11:19
05-03-2020 11:19
Best Answer05-03-2020 11:39
05-03-2020 11:39
Best Answer05-03-2020 12:25
05-03-2020 12:25
My first versa light started glitching it started going in and out, so they sent me a replacement one I just went to hook it up for my girlfriend and it’s got a big red X on it. They told me they’re working on it there’s a glitch in the programming. This was a replacement versa and all they did for me was send me a shipping label and told me to ship it to them. That’s all they did, hopefully when I get it back it will be working properly. All I can tell you guys, is call and keep calling to get your resolution to the big red X. In my opinion this is a faulty Fitbit, it should be pulled off the market, they should contact the customers that have them and have them all either sent back to them, or replace them all, because obviously there was something wrong with the Fitbit’s.
05-03-2020 12:29
05-03-2020 12:29
I just bought another versa 2 about 6 months ago and when I was talking to them I asked if I should update my versa 2 or leave it alone because I’m worried that it’s going to start this glitching. They told me it should be fine, it should be no problems. What do you guys think I should do.
05-03-2020 13:35
05-03-2020 13:35
05-03-2020 13:58
05-03-2020 13:58
thank you for you feed back.
Best Answer05-03-2020 16:27
05-03-2020 16:27
I'm having same problem, my device is only 10 weeks old.
Best Answer05-03-2020 16:28
05-03-2020 16:28
Whwre can you find the phone Number?
