07-26-2019
11:24
07:40
JuanJoFitbit
07-26-2019
11:24
07:40
JuanJoFitbit
My versa stopped working whilst on holiday in the pool. Come back on but red light on back of watch.
05-22-2020 05:38
05-22-2020 05:38
I called the customer service number from the app, 8776234997. It did take a few minutes to get a rep, but they did answer. If it helps, i called at 10 til 7, eastern standard time.
05-26-2020 02:04
05-26-2020 02:04
Get a refund if you can....dont ask for replacement as it wil fail as well in some time....
05-26-2020 02:12
05-26-2020 02:12
Looks like lots of people reporting this now....a fatal flow in their latest firmware update i guess.....watches going beyond repair !
05-26-2020 16:20
05-26-2020 16:20
How did they resolve your problem?
05-26-2020 18:25
05-26-2020 18:25
Not resolved yet. They asked me to do a battery test. I sent them the start and finish times 3 days ago but haven’t heard anything back at this point.
05-27-2020 12:18
05-27-2020 12:18
No resolve for me either, just an offer for 25% off a new one. No thanks! This has been very poorly handled apparently.
05-29-2020 21:10
05-29-2020 21:10
The last few days my Fitbit has not been tracking my heart rate or steps. Syncing has been an issue as well. Eventually My red light stayed and battery dying fast. I have done all the troubleshooting steps and nothing seems to work.
05-29-2020 23:22
05-29-2020 23:22
I have the same issue and this is on the replacement versa of the last one that just stopped working for me, altogether. This one is now giving me a blank screen and a red light. Such a waste because it was replaced in September 2019, and it’s not even a year later! I think these are not really swim proof like they claim. We all need to get our money back ASAP!
06-10-2020 05:52
06-10-2020 05:52
Mine is doing the same thing battery draining fast, now the red light on the back is on and it keeps dropping steps. What the heck, I don't even have the heart monitor on? So I have turned off and restarted it yesterday! Now yhis am same thing had 500 plus steps then it went to 72 and flickered??? What a drag!! So now I need to find out when I purchased it and take it from there. This is my 5th fitbit product that I have bought, I have given 2 away, lost one and still have my old alta!
06-15-2020 20:40
06-15-2020 20:40
06-16-2020 04:30 - edited 06-17-2020 16:20
Update: The issue appears to be a problem with the battery. But since my Fitbit is out of warranty and they say there’s no way to replace the battery, there’s nothing I can do. They offered me a 25% discount off a new one. The frustrating part is that with the Father’s Day sale right now, new Fitbits are already 25% off and you can’t combine discounts. So they basically offered me nothing. Ridiculous.
06-16-2020 07:30
06-16-2020 07:30
Thanks for the info. Yes that sucks, they always get ya o e way or another. 🙄🙄
06-21-2020 22:19
06-21-2020 22:19
Had similar problems, just deleted watch from app and re entered info as if it were initial and viola! It worked for me . Reset did nothing...hope this works for you all..
06-22-2020 04:03
06-22-2020 04:03
06-22-2020 09:07
06-22-2020 09:07
Not going to work if the whole thing literally won't turn on...
06-27-2020 04:29
06-27-2020 04:29
I'm also experiencing the red light issue. Has there been a firmware update ? Too coincidental that so many are experiencing the same issue at the same time.. I've owned 3 fitbit devices and after the Versa no find my phone feature was never addressed by the company, I was already considering going with another product. This may be the straw that sends me to Samsung
07-06-2020 15:23
07-06-2020 15:23
Mine is doing the same. Fully charged. I’ve shut it down. I did a reset. I also shut the heart monitor off. Waited. Turned back on. This red light doesn’t is bright and doesn’t go away. I have the Fitbit Versa. Got in Nov 2018. I use this daily. I need this watch to function.
07-31-2020 12:52
07-31-2020 12:52
I have had the same issue. This is my 2nd Versa. I was offered a 25% off a versa light. I purchased a brand new one to replace it. Had the exact same issue, it says it can be in water then it begins to malfunction after being in water. I changed it fully, reset, then it just continues to cut itself on and off showing only the fitbit start up screen. There's something wrong if this many people experience the same problem and from the thread it appears this has happened multiple times to most of it. Its very disappointing for such a well known brand to continue making products with these problems. It is also frustrating when you find a product that is so easy to work with except with it comes to problems. Any suggestions on a different watch to try?
08-08-2020 09:41
08-08-2020 09:41
I tried your suggestion but the red light is still on!
08-08-2020 16:19
08-08-2020 16:19
