11-01-2019 04:29
11-01-2019 04:29
Hi all,
I had a properly working Versa until I did the last firmware update (now on 32.68.9.15).
Since then, I no longer get Reminders to Move 10 minutes before the hour. Syncing works as expected. I don't use any other notification.
I have re-installed the Fitbit app on my phone and am reluctant to do a factory reset.
Can anyone suggest anything?
Is there a way to downgrade to the previous firmware version?
Thanks in advance.
11-01-2019 08:19
11-01-2019 08:19
Try a Restart and do it several times if necessary, No, you can not go back to a prior OS Version.
11-02-2019 08:34
11-02-2019 08:34
hi,
thanks for taking the time to reply - much appreciated.
i restarted my versa six times which for some reason resulted in me no longer being able to sync with my phone.
had to do a factory reset which resulted in me losing a day's data.
now back to square one - factory reset versa but still no reminders to move.
does anyone have any other suggestions?
thanks in advance
11-02-2019 08:49
11-02-2019 08:49
Contact Customer Support.
11-02-2019 08:56
11-02-2019 08:56
will do - thanks again for your assistance.
