06-24-2019 12:42
06-24-2019 12:42
It is ridiculous that I cannot send my fitbit in for repairs in South Africa, physically their is nothing wrong with the device not even a scratch the only problem is the screen has gone further everything works
06-24-2019 13:24
06-24-2019 13:24
It has nothing to do with South Africa. There are no repair centers anywhere.
As an aside, I have no idea what you mean by "the screen has gone further ".
06-24-2019 13:27 - edited 06-24-2019 13:34
This is what i mean
06-24-2019 13:32 - edited 06-24-2019 13:36
It is literally just the screen that went the backlight and everything else works fine, so instead of sending it in for a screen repair I must now buy a new unit, which is the problem I have, it is like a cellphone’s screen going and then instead of replacing just the screen you must buy a new one
08-31-2019 21:56
08-31-2019 21:56
The exact same thing happened to my versa on Friday. Out of the warranty period as l have had the watch now for a year and a month. No idea where l can get it fixed
09-02-2019 02:00
09-02-2019 02:00
09-02-2019 05:34
09-02-2019 05:34
my versa is 1 1/2 years old or a bit less.. and the screen is starting to go
during day time.. i have to setup the brightness to Normal or it gets too dark and i cant read anything
during night time.. i put the screen to Auto as normal is too bright....
I feel that i only have a month or two left with my versa 😞
I even done a factory reset in case.. it was the problem.. but no.. it is just crapping out slowly and nothing we can do.. other then start shopping for a new watch
09-02-2019 07:17
09-02-2019 07:17
Thank you. I will contact Garmin and see if they will be able to assist
11-18-2019 05:34
11-18-2019 05:34
This is exactly what i am trying to get sorted as well.
Versa about 1.5 year old and then one day the screen just died. Nothing works no reset, hard reset, factory reset.
Now trying to find out how to fix it and where?
12-05-2019 20:12
12-05-2019 20:12
Exact same happened to mine. Only 7 months old. Screen is just dead. I cannot even charge it.
01-27-2020 03:14
01-27-2020 03:14
Same here. Versa just died after factory reset. Fitbit support was helpful but could do nothing.
01-27-2020 03:16
01-27-2020 03:16
You should be able to return your watch if it is within the 12 month period. take it back to the store you bought it from with your receipt. Alternatively contact Fitbit support as they will assist with warranty issues. Do it before the 12 month period. Thereafter you are on your own.
01-27-2020 06:58
01-27-2020 06:58
Problem is if you out of warranty then yes you are on your own. There is no Fitbit service centre or even an accredited place to help fix issues. Will keep hunting, but sad to say that my fitbit is collecting dust now
01-27-2020 07:04 - last edited on 07-02-2020 20:58 by LiliyaFitbit
This is shocking honestly!!!
I bought mine in SA April last year.
We went overseas until August.
So unfortunately I misplaced my receipt in transition.
I bought it at Dischem!
Kind regards
03-08-2020 10:58
03-08-2020 10:58
I bought two Charge 3 on Amazon last year about May/June 2019. Now one is malfunctioning (gives the wrong time, and I cannot resynch it to my iPhone - tried everything that I could Google and also from Fitbit site) , and the other one works fine but the screen no longer works. Both Charge3 units malfunctioned on Friday, 6 March 2020. Too much of a coincidence that both should malfunction on the same day, so I'm thinking that this is a factory faults. Would appreciate it if someone could tell me where I can take my units to be repaired or replaced under guarantee / warranty.
04-23-2020 11:14
04-23-2020 11:14
Hi , my fitbit versa went flat and now it does not want to charge or go on again the screen is just black what can i do about this ?
04-24-2020 14:14
04-24-2020 14:14
I am truly disappointed with the lack of Fitbit product after sales. I eventually had to throw both my dysfunctional fitbit Charge 3 away. I've moved over to using Garmin now and it took me a day or so to adjust to the change , but now I'm happy with Garmin. Not going back to Fitbit in a hurry.
04-24-2020 14:15
04-24-2020 14:15
I bought a Garmin. Am happy now.
05-03-2020 23:28
05-03-2020 23:28
05-03-2020 23:29
05-03-2020 23:29
Did you ever find a solution to fixing your Fitbit in RSA?
