Require alarms to snooze or turn off using physical buttons?
I use the alarms function on my Versa to wake me up each morning, but sometimes I don't get the alarm at all.  I'm assuming that happens because my wrist movement while I'm asleep causes something to tap the screen in the right spot to turn off the alarm.  Is it possible to change this behavior and require using the physical buttons on the device to snooze or turn off the alarm?
1 REPLY 1
@Jazzman123 This is a good idea. Perhaps you could browse Feature Suggestions Forum and if no one has suggested it, you could add it?
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
