02-20-2019 17:00
02-20-2019 17:00
My resting heart rate hasn't changed for several days. The Versa seems to be tracking my heart rate accurately, but the resting heart rate has been 70bpm for the past 7 days. In the past, even when my heart rate is relatively steady, the resting heart rate changes by a point or two every day or so. Is there a problem?
Best Answer02-21-2019 07:39
02-21-2019 07:39
Hi, maybe or maybe not. What you could try to do, since the resting HR is needed to accurately monitor your Sleep. twofold:
1. Restart you Versa several times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons.
2. On you phone, close the Fitbit app and deinstall it. Do not remove or unpair your Versa. Restart your phone and reinstall Fitbit app and turn BT on and sync with your Versa. Good luck!!
02-21-2019 07:39
02-21-2019 07:39
02-21-2019 10:51
02-21-2019 10:51
I tried this, and my resting heart rate seems to be updating. Now it's 69bps. Thanks!
05-11-2019 07:58
05-11-2019 07:58
My Versa Lite is not tracking my sleep or updating my resting heart rate. I only have one button on my tracker. Any suggestions?
Best Answer12-26-2019 21:24
12-26-2019 21:24
Versa2 is tracking my heart rate fine but not updating daily resting heart rate. It has been stuck on same value and not showing daily rate on past 30 day/monthly graph since it got stuck. I’ve restarted Fitbit, factory reset, uninstalled and reinstalled app.... The suggestion here doesn’t work for me. Any other ideas?
01-08-2020 09:46
01-08-2020 09:46
I have the same issue. RHR is not changing even though sleeping resting heart rate is very low.
Best Answer02-01-2023 21:25
02-01-2023 21:25
I have had this same issue with my charge 4
Best Answer02-01-2023 21:54
02-01-2023 21:54
Did anything work?
