04-07-2020 02:13
04-07-2020 02:13
Hi
my versa was showing a heart rate of 200 when I was asleep.its now showing my resting heart rate between 110-170. Which is obviously wrong! My normal resting rate is between 48-54. Has anyone else experienced this and l know how to fix it?
04-07-2020 03:55
04-07-2020 03:55
It might occur when you wear the Versa too tight or too lazy. I recognized that when ít is very low ön battery, ít is not so precise.
But this can also be a fault of the sensor.
(48-54 of resting heart rate means that you are a very well-trained long distance runner or something like that. RHR is not the lowest heart rate during the night.)
04-07-2020 04:02
04-07-2020 04:02
04-07-2020 22:51
04-07-2020 22:51
Sure, my guess is then the same, ít is faulty.
