01-17-2022
00:33
20:34
01-17-2022
00:33
20:34
There is still no integration with the notifications from the Amazon ring doorbell.
This can be integrated, as it has been on every other watch/tracker that I have owned.
Can this be sorted?
01-17-2022 06:36 - edited 11-13-2023 11:09
Hi there, @TrickyDee. Thanks for stopping by in the Community Forums.
Have you verified if the Ring Doorbell app is also updated to the latest version?
I'd recommend trying the steps below in the order listed even if some of them you've already attempted:
For more troubleshooting steps, see Why are notifications delayed or missing?
Hope that helps.
01-21-2022 00:40
01-21-2022 00:40
No solution.
There are workarounds using various configurations of Alexa, it's an issue with the ring app apparently.
I guess that as you are Google and Ring are Amazon, we will do well to expect any sort of solution.
R.
01-21-2022 02:12
01-21-2022 02:12
Hi @TrickyDee - are the notifications that don't appear on the watch, actually appearing on the phone as notifications?
If so and you have an Android phone here is another workaround
01-21-2022 03:30
01-21-2022 03:30
Weirdly I had looked at using one of my free macrodroid macros to do just this, this morning.
01-21-2022 16:21
01-21-2022 16:21
There are posts over several boards. Is this happening on both iOS and Android?
It probably has nothing about the tracker.
