09-17-2019 14:05
09-17-2019 14:05
Hi Fitbit,
Please do not send me the link to the why my device doesn't connect, I've tried them all already. Please see below. I also emailed: android@fitbit.com
09-17-2019 15:46
09-17-2019 15:46
I’m sorry to say. @TimD7291 , that your Note 8 is not a compatible device. The problem is not with your Fitbit devices. It is with your phone. The Moto Z is a compatible devices, which explains why it works.
09-17-2019 15:58
09-17-2019 15:58
@SunsetRunner what do you mean? My phone has worked with the Ionic and Alta during setup. Do you just mean on the Versa 2? If so will it ever be a compatible device?
Can you elaborate more on why it's not a compatible device. The note 8 is an incredibly new phone and it's mostly OS that dictates compatibility so does that mean there's a large number of android users effected by this?
Fitbit doesn't have information listed anyway, so they basically con'ed me into upgrading to a Versa2?
09-17-2019 17:33
09-17-2019 17:33
09-18-2019 06:07
09-18-2019 06:07
@TimD7291 - Sorry for the confusion. It was my understanding that your problems occurred with the Note 8 but that you were able to get things to work with your work phone, the Moto Z. If a phone is listed as a compatible device, it means Fitbit has tested the functionality and determined that it is compatible with all Fitbit devices. If a phone is not on the list, it means Fitbit has not tested it (yet) and cannot guarantee the phone will work with Fitbit devices or that all the Fitbit features will be available. The list is focused on phone compatibility, not individual Fitbit devices. We do not have a timeline for which phones Fitbit will be testing, or when. There are a lot of phones out there!
Some people have successfully set up Fitbit devices to phones not on the list by making sure the Android phone is At OS 7 or greater. And also verifying that they are on the latest version of the Fitbit app. Bluetooth has also been a problem at times. I’ve personally found that it is best to set up a Fitbit device in a room with no other Bluetooth devices.
09-23-2019 16:51
09-23-2019 16:51
My wife's Versa 2 will not get messages from her Pixel 2 XL (Android).
Hey Fitbit - how about you fix these comparability issues. Remember all the issues you were having with the bands?
09-24-2019 18:12
09-24-2019 18:12
09-24-2019 23:22
09-24-2019 23:22
Could be android battery settings. Try this it worked for me https://youtu.be/a91CDZh3LlQ
11-29-2019 11:31
11-29-2019 11:31
I'm having the same issues. I called Fitbit tech support, and was told the Versa 2 doesn't work properly with the Note 8. He said I should set it up with my tablet and accept the fact that when I'm out with my phone I won't get notifications...what a joke! Of course, you don't learn this until after you purchase the watch, Fitbit really dropped the ball on this one!
11-29-2019 15:27
11-29-2019 15:27
Never been so unhappy. Was so excited to get the new fitbit versa 2 and now because I have a note 8 it will not work. So what go buy another 1000.00 phone so my fitbit works?what a bite in the **ahem** this is. Very unhappy customer.
12-05-2019 12:06
12-05-2019 12:06
Update: I downloaded the "Fit Notifications" app in Google Play. After setting it up I'm getting all my notifications.
12-10-2019 14:08
12-10-2019 14:08
Hi , with Fit Notification app what settings did you make?
12-10-2019 14:13
12-10-2019 14:13
I have downloaded the app Fit Notifications for my Sprint Note 8... before this .. i was not getting phone call notices.. now i am... i am still not getting text notices. i have also changed Fitbit app permissiions on my cell to allow sms texts. don't know what else i can do... i'll keep checking for tips.
01-11-2020 20:48
01-11-2020 20:48
So why is the Note 8 not compatible when it was previously?
01-19-2020 12:49
01-19-2020 12:49
This was an expensive way to find out that the Fitbit is not compatible with my Note 8, but it will be one that ensures I will never buy another Fitbit!
