10-30-2021
07:57
16:34
DavideFitbit
10-30-2021
07:57
16:34
DavideFitbit
Best,
I have a Fitbit Versa 2 that worked fine until yesterday.
However, today I cannot operate the screen with it.
The watch works and everything is registered.
Also the synchronization with my smartphone works fine.
But the touchscreen is therefore no longer responding to touches so I cannot operate the watch.
I have already tried a soft reset several times without desired result. However, a hard reset or factory reset is not possible because I cannot operate the watch via the screen.
Can someone help me with tipts and trics please?
Thank you.
10-30-2021 16:33
10-30-2021 16:33
Welcome to the Fitbit Community forums, @DaveBB82.
Thank you for sharing that you've been experiencing this inconvenience with your Versa 2 watch and that you already tried a few troubleshooting steps.
In this case, since you already tried the restart procedure and you continue to have the same problem, I recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
11-02-2021 15:39
11-02-2021 15:39
I had the same issue this past weekend. I let the battery run down completely and when I charged it it worked fine. Hope this helps.
11-02-2021 22:04
11-02-2021 22:04
Hi, I am experiencing the same issue todas november 2nd...
Is tiene a way to be able to fix it?
Regards,
Sharmaine
11-10-2021 17:32
11-10-2021 17:32
That's great news, thank you for sharing this update, @JML1970!
Thank you for sharing that you've been experiencing the same inconvenience with your Fitbit watch, @LuckySharm. I've been informed that you already contacted the Customer Support team for further assistance with this, let me know if you're still experiencing this problem.
I'll be around.
11-10-2021 18:59
11-10-2021 18:59
I am also experiencing the same thing as of yesterday 11-9…. Something just switched on it for no reason.
11-17-2021 07:09
11-17-2021 07:09
Hi, welcome to the Community forums, @sarahmann54.
Thank you for sharing that you've been experiencing the same inconvenience with your Versa 2.
Please make sure that you've tried the restart procedure as described in this article. If you continue to experience the same problem after the restart, I recommend that you get in touch with the Customer Support team so they can let you know how to proceed or provide you with more instructions.
Have a good day.
