05-05-2018
23:45
11:34
DavideFitbit
05-05-2018
23:45
11:34
DavideFitbit
The versa is still working, but why does my versa screen not show anything. it just black!! can anyone tell me why. I just brought it 15 days ago:(
Moderator edit: format
05-06-2018 07:47
05-06-2018 07:47
Both of you should do a RESTART and do it several times if necessary.
05-06-2018 06:16
05-06-2018 06:16
The same thing happened to me this morning. I woke up and the screen is black. I just got it last week.
Does anyone know why this is happening and what to do about it?
Best Answer05-06-2018 07:47
05-06-2018 07:47
05-06-2018 09:45
05-06-2018 09:45
did you find any solution? because my versa is still not working. thank you
Best Answer05-06-2018 10:30
05-06-2018 10:30
@cs6890342 wrote:did you find any solution? because my versa is still not working. thank you
You can try a Factory Reset and if that doesn't work, contact Customer Support. For the Factory Reset, swipe left to settings, touch About and then Factory Reset. You will lose any changes you made since starting up your tracker.
Best Answer05-07-2018 05:32
05-07-2018 05:32
That worked. Thank you. My fitbit is back to normal.
Thanks again,
Kathy
Best Answer05-07-2018 05:33
05-07-2018 05:33
Try restarting it. Hold down the left button and the lower right button for 10 seconds or so and it should start right up.
Best Answer05-09-2018 19:36
05-09-2018 19:36
Thank you! Worked! Not sure why it happened?!
Best Answer05-14-2018 14:17
05-14-2018 14:17
Best Answer05-14-2018 15:55
05-14-2018 15:55
I tried to restart mine pushing the left and the bottom right buttons and nothing happens. The heart test sensor and the vibration are working fine. The display is the one that “shut down”
05-14-2018 15:56
05-14-2018 15:56
Versa
I tried but when I hold the button it does not work and I tried several times. What can I do now?
Best Answer05-14-2018 15:57
05-14-2018 15:57
I have axactly the same problem
Best Answer05-14-2018 16:08
05-14-2018 16:08
Hi,
Try turning it off and then back on again. That fixed it for me.
Best Answer05-14-2018 16:12
05-14-2018 16:12
Already tried that
Best Answer05-14-2018 19:02
05-14-2018 19:02
Tried to restart but the display is “dead”
nevertheles the heart rate sensor and the vibrations are working.
05-14-2018 22:40
05-14-2018 22:40
Axactly
