12-25-2018 19:05
12-25-2018 19:05
Since I did the update I have to physically tap the screen in order for it to turn on. It used to turn on with the turn of my wrist. Is there anyway to fix this?
12-25-2018 19:14
12-25-2018 19:14
Hold in the left button a few seconds to get to quick settings screen. At the top is 'Screen Wake'. Tap to toggle between Auto and Manual. You want Auto.
12-25-2018 19:14
12-25-2018 19:14
12-25-2018 19:48
12-25-2018 19:48
Thank you. I feel stupid, that was to easy...lol
01-13-2019 16:05
01-13-2019 16:05
Thank you. Not sure why it was off. Still learning how to use my Versa!
03-14-2019 08:04
03-14-2019 08:04
I had the same problem. I have it turned on in the app on my phone but for some reason it had turned itself off.
Thank you for the solution. That worked.
But - If it is turned on in the application on my phone, why is it set to manual on my versa?
Strange.
08-30-2020 18:08
08-30-2020 18:08
Turned on alexa
08-30-2020 18:13
08-30-2020 18:13
@Radcliffitnes wrote:Turned on alexa
Look for Screen Wake in Settings (scroll right from clock face). Since users can change what left button does, functions are not always the same place for everyone.
08-30-2020 22:08
08-30-2020 22:08
