04-19-2018 13:51
04-19-2018 13:51
Versa arrived yesterday. Set it up with phone app, it synchs, etc. BUT the Versa screen won't swipe! Not sensitive to taps, double taps, etc. I have tried restarting by holding left+bottom right buttons many times. Still no screen touch sensitivity.
04-19-2018 14:00
04-19-2018 14:00
You might want to call support for this issue. ..
Best Answer05-15-2018 22:21
05-15-2018 22:21
I have the same problem. Mine used to swipe but no longer does. And the touch screen is not operable.
05-16-2018 07:27
05-16-2018 08:07
05-16-2018 08:07
06-15-2018 01:34
06-15-2018 01:34
This is the worst advice ever! Why would your even post if you can't give a valid solution.
07-08-2018 02:09
07-08-2018 02:09
I've had mine a month and has developed the same problem.
Best Answer07-08-2018 02:12
07-08-2018 02:12
But that's exactly what you've done. I assume people are warning that this is a common rather than isolated fault and that Fitbit needs to rectify the issue.
Best Answer04-19-2019 04:28
04-19-2019 04:28
I am too facing the same issue
Best Answer04-19-2019 09:31
04-19-2019 09:31
