04-22-2018
14:30
15:34
AlessFitbit
04-22-2018
14:30
15:34
AlessFitbit
Setting the screen wake option to Auto works as expected (a bit too senstive though), but setting it to manual doesn't seem to work. The screen still turns on when I move my wrist.
Moderator edit: title for clarity
12-24-2018 07:29
12-24-2018 07:29
Jogger, I did the update yesterday and it doesn't make the problem go away on Android. I'm glad to hear at least it's working on IOS. For those of you still dealing with this issue, here is a suggestion. I'm now using an all red watchface: "Simple stats Clockface", which since it emits only a red light, it's less prone to wake you up if it goes off at night.
Best Answer12-24-2018 08:39
12-24-2018 08:39
I noticed that mine is also staying off a hella lot more and my battery is lasting 3 or 4 days again! I'll take a Christmas gift as well, even though it was wrapped in hell to get through! Thanks community! Keep chatting it up I'll leave the thread open
Best Answer12-24-2018 10:02
12-24-2018 10:02
I also updated my fitbit. Screen is staying off allot more. But now when i get a notification my screen goes on... never had that before. Is there any solution?
Best Answer01-09-2019 23:45
01-09-2019 23:45
I turned quick view off so the display wouldn’t keep turning on on my Versa and draining the battery. It’d be quicker and more convienent if I could turn quick view on/off from the Fitbit instead of using my phone. That way, it can be more easily turned on when working out or turned off for sleeping.
Best Answer05-01-2019 18:13
05-01-2019 18:13
Yeah manual screen wake does not do what it should. When I put it on manual screen wake it's usually only when I'm at the movies. But it still is waking up when my wrist turns towards me! How annoying and useless of a setting. When I turn it to manual wake, it should ONLY turn on when i PRESS a physical button. No movement, no tapping, only physical button presses.
05-02-2019 03:38
05-02-2019 03:38
