See actual weight on Dashboard
Using Android App and dashboard only shows weight change and progress toward goal.  How can I get it back to showing actual weight?
2 REPLIES 2
I think that happens when you have a weight goal set.  If you removed your weight goal, I think it would return to showing actual weight.
How do I remove? Only see how to change it
⁣Lauren and Lowell Babus ​
