05-01-2018
06:23
10:26
AlvaroFitbit
05-01-2018
06:23
10:26
AlvaroFitbit
Hello 🙂
I would like to know if anybody is using the fitbit pet cat or dog watchface. I cant set the clock to 25 hrs. My phone is on 24h and also my settings on my fitbit acount. Is it even possible? Thanks 🙂
05-02-2018 10:31
05-02-2018 10:31
@kitten0000 Welcome to the Fitbit Community! I hope you're doing well! For the clockfaces they will work with the defined setting, in this case the Pet clockface has a 12 hours setting so you won't be able to use it in the 24 hours one. You can look for another clock face that has this setting.
I'll be around!
06-16-2018 08:58
06-16-2018 08:58
ine says 04.58 when its 16.58 no am or pm its infuriating
07-02-2018 09:27
07-02-2018 09:27
@jackibooo A warm welcome to our Community! As mentioned before the clockface will only work with its defined setting so you won't be able to use it with the 24 hours setting. You can share your idea in our Feature suggestions board. The more votes an idea gets the more likely the developers will try to implement it.
Keep me posted!
