12-28-2022 04:49
12-28-2022 04:49
Can I customize the buttons on the right side of my brand new Versa (original)? Currently, one goes to exercise, which is good. The other goes to alarms, but I want it to go to the "Today" screen. Is this possible? Thanks
12-28-2022 05:19 - edited 12-28-2022 08:58
Hi @CrystalClearly - the left button goes to Quick Settings by default and can be configured in watch Settings, Left button, to a few other things.
The top right button opens the app located in the top left position of the Apps launch screen [when you swipe the face left] and if held it goes to Notifications.
The bottom right button opens the app located in the bottom left position of the Apps launch screen.
Btw, the original Versa is normally a great watch as everything works. To make it last, avoid, getting it wet, updating the firmware or doing a factory reset, if at all possible.
When you swipe the face left, you can hold and drag the launch icons to whatever postions are the most useful for you and put the ones you want in those 2 special positions.
12-30-2022 04:33
12-30-2022 04:33
Thanks for a very clear explanation. My versa buttons are set exactly as I want them, and it was easy with your explanation!
12-30-2022 04:38
12-30-2022 04:38
Also thanks for the tips on keeping my Versa running. I chose a Versa because it had nearly all the features I wanted (counting stairs climbed was a big one, since my main exercise is walking in the local hills) plus it didn't have a microphone. Having a microphone was an absolute show stopper for me. The only thing that I miss, which my Charge 3 had, is the SpO2 feature. Add it to an original Versa, and Fitbit would really hit the mark!
12-30-2022 06:39
12-30-2022 06:39
I saw your separate post and linked a Help article.
Laurie | Maryland
