10-22-2019
06:33
09:08
AlvaroFitbit
10-22-2019
06:33
09:08
AlvaroFitbit
Brightness, screen wake, and Do Not Disturb are "greyed out" on the Versa "Settings".
I just switched from iPhone to Android. The Versa is synced. How can I set the Brightness to Auto?
10-23-2019
09:09
11:02
10-23-2019
09:09
11:02
@rpspiker It's great to see that you've visited the Fitbit Community!
Let me help you with your Versa not showing all the options now. Try restarting your watch by following these instructions.
Let me know how it goes.
Best Answer11-13-2019 19:13
11-13-2019 19:13
I think I know the answer. I had something similar on my watch when I put it into sleep mode inadvertently.
12-09-2019 21:08
12-09-2019 21:08
Did you get this fixed? I just did an update and my do not disturb, brightness, and screen wake are all still greyed out and I cannot change the settings. So my fit bit does not let me know I have incoming calls or text messages.
12-27-2019 22:47
12-27-2019 22:47
Same deal, it was resolved when I took it out of sleep mode. Didn't realize I'd had it in sleep mode. Swipe down to view your options (it's next to the music symbol) and click the little moon symbol. Problem solved!
02-01-2020 19:54
02-01-2020 19:54
I also have the same issue. How did you fix your issue ?
Best Answer02-01-2020 22:31
02-01-2020 22:31
Go back to the settings options and take the watch out of sleep mode - that should solve your problem
05-28-2020 12:38
05-28-2020 12:38
Thank you! This solved the issue for me.
Best Answer08-24-2020 06:49
08-24-2020 06:49
Hello ! I have been struggling with the problem of MN the greyed out brightness, sleep mode and do not disturb. It wasnt until I read your post telling me how to find the half moon that I was able to fix it. Thank you ! That is not intuitive, nor does it show up on my phone app as a how to fix !
10-05-2020 18:27
12-30-2020 07:41
12-30-2020 07:41
Thank you so much! I had never seen those settings before after so much searching!! Fixed my problem.
Best Answer03-26-2021 12:34
03-26-2021 12:34
Thanks you *SO MUCH*. This is *exactly* what happened to me. I also had *NO IDEA* that I was in Sleep Mode. You need to get out of sleep mode by clicking the lit moon!
03-30-2021
11:49
11:02
03-30-2021
11:49
11:02
@DCFlaneur Thanks for stopping by!
Thank you for sharing your experience and for confirming how you fixed the issue as this may help other members in the same situation.
I'll be around.
Best Answer01-26-2022 17:33
01-26-2022 17:33
Well this option did not help me everything is greyed out, apart from screen wake, which is highlighted as I have it set to automatic...so help!
01-26-2022
21:52
10:35
01-26-2022
21:52
10:35
Hi @CelticQueen - do you have 2 watches? Your other posts are in the Sense forum.
In any case did you try to do a Shutdown of this watch from the Settings menu, wait 10 seconds and then place it on the charger to restart it and charge it.
It may be wise to start a new post with the exact symptoms if it continues.
Best Answer02-08-2022 21:26
02-08-2022 21:26
This did NOT work. All my setting options are grayed out. HELP…this is ridiculous
02-08-2022
22:22
10:35
02-08-2022
22:22
10:35
11-16-2022 19:31
