First off let me say this: I've had a Surge, Blaze and now a Versa. I also have the Aria scale. (Not the Aria 2, though...) I've had the Versa for about 4 months now. To say I've been underwhelmed with it is probably more accurate than disappointed. (Although disappointment does come into play after spending over $250 on it.)
I have had nothing but problems getting the Versa set up. When I DO get it running, it disconnects from one day to the next. Sometimes I can get it back, sometimes I can't.
Today I did a factory reset on the Versa. Still couldn't get it set up. At least until I removed the Blaze. Once I removed it from my Windows machine and deleted the apps on my tablet and phone, I was able to start the setup process. I hope I will be able to read the Blaze back in after the Versa is done.
I wear the Blaze at work, and had intended to wear the Versa for off times. So far that hasn't worked out very well. The Versa spends a lot more time in the caddie charging than it has on my wrist.
In any case, I hope other people with 2 or more devices can take something from this... Remove the older device, add in the newer and (hopefully) add in the older again. I've also found that making any device a default makes all of the less likely to sync, so I won't be doing that either... 😞
GL!
Best Answer@MikeG6.5, hello Mike. I had both blaze and versa on one account, I guess I have been lucky using both watches on one 1 account. Your watch will keep track of your stats and port them over providing you have auto sync set up or you do a manual sync if auto sync is not set. You should have no problems using both watches. If you use your blaze to work and switch to your versa, your stats should sync to your account. I know a lot of people are having syncing problems just using one watch. I have the iPhone so far no problems.
