05-19-2018 12:01
05-19-2018 12:01
Versa battery was lasting 4+ days until the recent update.
After the update the battery died in less than 24 hours.
I have rebooted and restarted my versa and android phone, pressed and held the back (left) and bottom buttons until I saw the Fitbit logo on the screen, and fully recharged the versa several times.
I am now getting almost two days.
Please don't tell me to shut off all the smart functions to save battery ... I didn't buy this to be dumb.
Any other advice would be appreciated.
05-23-2018 06:28
05-23-2018 06:28
@Roadbuilder Welcome! Thanks for being part of our Community! You seem to have tried most of the suggested troubleshoots for this issue. I would like to ask you to try the suggestions I shared here. Specially the ones about disabling all day sync and removing third party apps (not all the features like notifications as like you said you have the Versa for this reason) just to see if there is a change in its battery life. One final thing you could try is doing a Factory Reset (go to settings, about and Factory Reset) and setup your Versa again.
Let me know how it goes!
05-23-2018 08:12
05-23-2018 08:12
06-03-2018 15:01
06-03-2018 15:01
After many try's, I finally got my versa reset to factory.
Unfortunately, now it will not complete setup and is still unusable.
The app finds it; however, it will not connect .....
I have purged the versa from the Fitbit app and my android phone; rebooted my phone; rebooted the versa numerous times and it always finds it and then fails to connect.
For the record I can turn around and reconnect to my Ionic without any problems, (yes ... Ionic is in the other room and I am away from all bluetooth devices and five feet from my router).
Best Answer06-03-2018 15:34
06-03-2018 15:34
I had similar issue after performing factory reset. Try to remove "Versa" from the list of paired Bluetooth devices on your phone.
Best Answer06-03-2018 15:43
06-03-2018 15:43
I repeated all the steps again and removed the versa from bluetooth settings and it took this time.
Thanks.
Versa has now been factory reset and updated to the new firmware (3rd time and this is a painful process).
Now to see if the battery will hold a charge ....
Best Answer06-26-2018 07:45
06-26-2018 07:45
@EugeneB Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
@EugeneB Happy to hear that your Versa worked after removing it from the bluetooth list.
@Roadbuilder how is your Versa behaving after this? Try to limit the amount of alarms and the all day sync option to save battery. Also have you installed new apps or clock faces?
I look forward to your reply!
