05-14-2019 10:16
05-14-2019 10:16
Hello,
My Fitbit Versa is traking my HR even if it is on a table and I am not wearing it.
The green light is on and it shows 72btm
Thank you!
05-15-2019 12:21
05-15-2019 12:21
@Userici This is quite normal. If Versa can "see" any surface especially reflective one, it can get confused. To avoid this problem, I place by tracker on the side or belly up. 🙂 The sensor lights go off immediately.
05-15-2019 12:43
05-15-2019 12:43
@Marrrmaduke thank you for the answer, but the sensor should indicate the heart rate, how can it be accurate if the sensor measure the heart rate of any surface, even if it isn't reflective.
05-15-2019 12:46
05-15-2019 12:46
@Userici The sensor is actually pretty accurate. I had it tested against chest strap. But, as I say there are no things that are perfect. If it stays on your had, it will be pretty accurate. I know it's not what you would like to hear, but I cannot offer bulletproof solution here. 🙂
