01-01-2020 04:51
01-01-2020 04:51
I am using Versa 1, it is good to me. I wear it every time of a day, special when i have shower. I want to upgrade to Versa 2, but i am scary about the water can break into the versa 2 throught microphone hole. On Versa 1, i am scary water break into watch by alimetter hole (using to count floor) too. So that on Versa 2, I have some worry about microphone alimetter hole. Can you reassure to me? Thanks you
01-01-2020 05:38
01-01-2020 05:38
No, you should not. It don`t work at all.
01-01-2020 05:43
01-01-2020 05:43
Really? That's sock news to me 😞 i dont have swim, but i have to wear it when i shower everyday. 😞
01-01-2020 06:10
01-01-2020 06:10
I bought mine mid october, and used it for one week before it hanged. not been able to use it after that.
They claim Ios is the problem, and i get that, if it only was notifications, but the clock is not responding at all. Touch screen works max one time a week, and if you let it sleep, it does not respond again for a week or two. It was a very good clock until this happened, but it`s useless as it is now 😕
01-01-2020 06:24
01-01-2020 06:24
Thanks Matkri.
I have regret for your watch.
Have it warranty or renew by fitbit? Maybe Versa 2 is lates version, so that it dont have more time to fully test by Fitbit
01-02-2020 04:55
01-02-2020 04:55
I would not recommend the Versa 2. I have had nothing but issues with getting mail and texts on the versa 2. I have asked for help from fitbit and got nothing. Stay with what you have or go to Garmin.
01-02-2020 05:35
01-02-2020 05:35
@LongLe19101 I have a Versa and a Versa 2 and can give you a side by side comparison.
Versa 2 pros:
Versa 2 cons:
I take my Versa 2 off when showering. Fitbit recommends giving your wrist a rest. I also use that time to clean the underside of it. It can get icky if you exercise and sweat a lot. So look at these pros and cons and choose for yourself.
Laurie | Maryland
