01-02-2019 10:13
01-02-2019 10:13
I downloaded the Sickweather clock face onto my Versa, but it the SickScore data is not showing up on my screen. I have set it up to run in background and access to all the permissions, but even so it will not show the information for my location. Is there something else I need to update?
01-02-2019 11:26
01-02-2019 11:26
Hi, Sickweather is a third party Clock Face. After updating to the newest Firmware .30, several third party CF stopped working due to incompatibility with the new version. You can check that by installing a Clock Face developed by Fitbit itself, either "Layers" or "Light". You know how to do that. If these one work, the one your using now is not compatible.
01-02-2019 15:27
01-02-2019 15:27
Got it, thanks for the prompt explanation!
05-15-2019 17:55
05-15-2019 17:55
Hi -- We updated the SDK today, so this should be working correctly now. Sorry for the delay and inconvenience!
10-19-2019 20:20
10-19-2019 20:20
Is sick score not working again? I’m not seeing any sick score or temperature. This is definitely the clockface I’m looking to use, but seems to be missing its ability to function at the moment.
