12-14-2020 18:07
12-14-2020 18:07
I was playing around trying to learn how to navigate my new Versa 2. I set a mon-fri silent alarm. I decided I dont want it anymore and there is no longer a silent alarm on the app. when I try to delete it from my Versa 2 it only gives me an option to add another. Ugh this is annoying. I hate to reset to factory but I will if I have to.
12-14-2020 18:28
12-14-2020 18:28
On your wrist, from clock face, scroll right to 'Alarms'. Find the alarm of interest and tap it to select, then scroll down to 'Remove'.
12-15-2020 03:32
12-15-2020 03:32
12-15-2020 08:12
12-15-2020 08:12
@Melo_d wrote:
on the watch it doesn't give me an option other than to "add" a silent alarm
I can't explain it any better than in my post above.
Quoting from How do I manage alarms on my Fitbit device?
"To delete an alarm on Charge 4, Ionic, Sense, Fitbit Versa series, open the Alarms app > tap the alarm > tap the trash icon or Remove. You may need to swipe up to see this option."
