05-03-2018
18:11
14:30
AlessFitbit
05-03-2018
18:11
14:30
AlessFitbit
Hi there,
Quite enjoying my new Versa, but would like to see a change in the alarm behaviour. It goes off for a very limited time, then stops whether it gets acknowledged or not. I’ve slept through this, and would prefer it goes off for 15-20 minutes before it turns itself off.
Unrelated and likely virtually impossible, I’d love to be able to be actively connected to two phones simultaneously. One of my most-used features is notifications, and I’d like to have both my personal and work phone buzzing me.
Thanks for your consideration! 🙂
Moderator Edit: title for clarity
05-03-2018 20:25
05-03-2018 20:25
It is VERY limited. Less then 5 seconds. I actually observed it since it wasn't waking me up. Made me think it didn't go off. So I set it, observed, and it vibrates for like 3 seconds and stopped regardless of if you tap the check sign or not. Too short really. Then starts vibrating for 3 seconds again after 9 minutes have lapsed. Please make it vibrates LONGER, Fitbit.
05-03-2018 22:10
05-03-2018 22:10
I agree. I previously had the Alta & Alta HR and they would vibrate until you double tapped the screen. It always woke me up. The Versa literally vibrates three short little bursts and then stops regardless of your actions/inactions and doesn't do it again for almost 10 whole minutes. 😞
05-30-2018 23:55
05-30-2018 23:55
Same here, I am an Apple watch convert and this is my only dissapointnent. Needs to keep vibrating until you acknowledge it.
06-01-2018 08:55
06-01-2018 08:55
The silent alarm was one of the main reason I purchased my Versa and it's essentially useless in it's current state of turning off after 3 seconds. I'd say this needs to be changed to vibrate for at least 5-10 mins before turning off automatically. Please fix this fitbit!
