03-30-2020
12:56
04:12
DavideFitbit
03-30-2020
12:56
04:12
DavideFitbit
Over the last couple of weeks I have on a couple of mornings been unable to dismiss my silent alarm. No amount of tapping dismiss or snooze has any effect. The only way I can get it to stop is to hold the side button in until the Fitbit restarts. Rather irritating 😠 , especially if you really want to snooze 😴.
Is anyone else having this trouble?
03-30-2020 13:48
03-30-2020 13:48
Maybe you already know this, but to you have to tap the check mark within the semicircle at the bottom right corner of display.
Best Answer03-30-2020 14:41
03-30-2020 14:41
😂 Yes I know that but I appreciate your input.👍 There’s bound to be someone out there that will find that tip useful. Thank you.
