Hey folks!
Are any of you having trouble with sleep tracking with your Versa?
Mine worked well for the first 2 days, then it started to not record/track. It was showing a lot of 'restless' sleep and broken sleep, which is not uncommon for me and one of the reasons I wanted this, but it seems to be just showing me a break down not an indepth look.
I'm waiting for a new band to come as I do think the silicone one, being some what stiff, is lifting it off my wrist while I sleep. I can't have it too tight or else I have an allergic reaction, but even so, it initially tracked my sleep fine with the fit this way. I think others are saying their fit bits aren't tracking correctly either and it seem to be more of an app issue rather than the fitbit itself?
I am elated with this regardless---ok, the only thing I DON'T like i when I reach a goal and it buzzes and scares me half to death, but aside from that 😉 😄
That's terrible!! Mine worked great to start, but now it's not tracking the full sleep cycles. I plan to enter my sleep manually tonight and see if it works tomorrow 🙂 Good luck with your fitbit! I love mine, so I am sure there is a solution to your issue.
