12-01-2019
05:26
08:44
YojanaFitbit
12-01-2019
05:26
08:44
YojanaFitbit
My Versa has stopped showing my sleep stats, exercise days and the weather app doesn’t work at all. I think it’s since the last iPhone update, but the stats on the phone are fine! I’ve reset the Versa, turned it off, turned off the Bluetooth & the phone. Any suggestions?
12-04-2019 09:03 - edited 12-04-2019 09:04
Hey @Simmojen welcome to the Community Forums. Thank you for reporting the missing information on your Versa since the last iOS update.
I really appreciate all the steps that you've tried in order to fix this inconvenience with your stats. Please confirm that your Versa and Fitbit app are up to date. Restart your Versa one more time and then try to sync it with your iPhone to update the information. If the issue persist, please attach an image of the information that you can see from your end.
Keep me posted on the resolution.
Best Answer12-04-2019 20:49
12-04-2019 20:49
12-06-2019 17:26
12-06-2019 17:26
Hi @Simmojen thanks for getting back to me. I really appreciate the steps you've tried with your Fitbit Versa. As you already confirmed that your Fitbit is up to date, please follow these instructions:
Give it a try and keep me posted.
Best Answer12-06-2019 22:00
12-06-2019 22:00
Best Answer12-07-2019 14:21
12-07-2019 14:21
Hi @Simmojen, thanks for confirming that information.
I really appreciate all the troubleshooting steps that you've tried until now. Sorry this is not working. I've requested a case on your behalf. You should soon receive an email from Customer Support. Please reply to them with the information that they will request.
I'll around in case that you need anything else.
