01-16-2021 18:47
01-16-2021 18:47
Me sleep info isnt syncing with my app.. everything else syncs and I know how to do it, but I go into my weekly report and my sleep info hasnt been shared so there is nothing to look at. I can see my hours I slept and if they were light, or deep, or rem or awake and I can see my weekly average on my versa but it wont transfer to the app..
01-17-2021 23:12
01-17-2021 23:12
First simple thing to check is a watch corruption. Restart it and resync.
Shut down the watch [ Swipe left, Settings, at the bottom, About, at the bottom, Shutdown]
wait a minute
[Hold the button till it vibrates or logo appears} Wait for the clock to reappear. |
01-17-2021 23:36
01-17-2021 23:36
01-17-2021
23:47
08:16
01-17-2021
23:47
08:16
What phone do you have?
If its an Android one try this procedure for future sleeps
Logout of the Fitbit app
In Android phone Settings Apps Fitbit clear Fitbit storage cache [not data] force Fitbit shutdown [though it doesn't seem to fully go away]
reboot phone
Login to the Fitbit app and sync |
01-18-2021 11:23
01-18-2021 11:23
01-28-2021 11:27
01-28-2021 11:27
So I now see that it isnt anything you've told me to do, it's your side that has a sync problem. Why didnt you just tell me that instead of making me reset my phone and my versa, you caused me to have to reload and re download a whole pile of stuff when it was as simple as saying we are having issues and many people have reported a problem as well.. thanks for you help I will be returning this versa asap..you guys sold me a defective product..period..
01-28-2021
11:45
08:15
01-28-2021
11:45
08:15
@SteveFryer44 The problem you had precedes the Fitbit app problem, which has materialised since.
There's now [January 25th] a bug in the last Fitbit App update for Android phones which stops phones syncing. This is a new issue.
Hopefully they will issue a fix soon. In the meantime if your watch works it will keep data for about a week and best to not make any changes till its fixed.
01-30-2021 18:53
01-30-2021 18:53
Okay my sleep isnt syncing and my heart rate is saying I'm at 111 beats while I'm sitting in a chair meditating..it says my resting rate is 74 but this watch hasnt shown 74 even once today and I've been checking the heck out of it because it's not work ih ng right..
01-30-2021
22:14
08:15
01-30-2021
22:14
08:15
If the heart rate is way off the watch probably doesn't detect any sleep, so no sleep to sync.
Restart the watch, and make sure the sensors on the back of the watch are clean.
If you don't get a reasonable heart rate probably best to contact Fitbit Support directly. They may be able to help you.
01-30-2021 22:26
01-30-2021 22:26
01-30-2021 22:35
01-30-2021 22:35
Hi, thanks, but first lets check your current versions to make sure it is correctly setup after the reset
What is your watch firmware version?
On the watch Swipe left Click on Settings Scroll & click on About Version near the top |
What is your Fitbit app version?
In the phone Fitbit App Click on profile photo [top left] Help & Support App Version at the top |
If your Fitbit App version isn't 3.37.1 then go to the Play Store look for Fitbit and update the Fitbit app
02-10-2021 11:54
02-10-2021 11:54
Hey.. so now my versa 2 wont sync at all. I've tried restarting and all the resets on my phone, it was working except for my sleep data not syncing but now nothing syncs..what do I do besides take it back
