After the last software update my Fitbit only shows the date and steps, but the steps always read 0. I used to be able to see my heart rate, calories burned, and stair count. The Fitbit app is counting my steps, but it is convenient to just look at my Fitbit and not have to open the app on my phone. Has this happened to anyone else, or do I need a replacement?
Best AnswerI'm using the one already on my Fitbit. Not from a third party, I'm not that smart. I didn't even know you could use another source.
Best AnswerHi , then try to reboot your Versa by pressing and holding the left and right lower buttons untill you see the Fitbit logo and release the buttons. Sometimes you have to repeat this procedure more than once. Good luck!!
