06-18-2018 20:01
06-18-2018 20:01
Do not see Sony Xperia X in Versa compatible list. Unable to buy product without compatibility confirmation. Please advise, target date for compatibility.
06-19-2018 02:23 - edited 06-19-2018 02:23
Hi ,I have Sony Xperia X and there is no issue with compability (it syncs, updates, notifications/calls work..)
06-19-2018 02:26
06-19-2018 02:26
@Subbu23 It may work (or it may not), but Fitbit will not tell you if they are working on your phone or when it is likely to be Supported
Helen | Western Australia
12-30-2019 16:18
12-30-2019 16:18
Mine worked then it didn't. Fitbit support said it wasnt compatible after it worked perfectly fine for 3 weeks. Had to play with it like crazy did a bunch of stupid things... Then it worked again. Think its the actual versa 2 thats the problem going to return it try a new one
