05-11-2019 17:47
05-11-2019 17:47
Why doesn't it to the total number of floors??? Why are there so many problems with so many features? Nothing works well.
05-11-2019 18:05
05-11-2019 18:05
Floors climbed are detected by an altimeter sensing changes in altitude. On a stairclimber, you are not increasing your altitude.
Best Answer05-11-2019 22:07
05-11-2019 22:07
Thank you. I thought the minimal going up and down would account for it. I guess not.
Best Answer05-11-2019 22:48
05-11-2019 22:48
It takes a ten foot altitude change to count as one stair set.
Best Answer10-26-2019 16:59
10-26-2019 16:59
I get that but why isn’t there a way to put in your steps when you log it, why are calories and time the only options to enter? Seems like that would be something that can be added to the algorithm in the logging section. We can log lots of details for other exercises.
Best Answer10-27-2019 04:05
10-27-2019 04:05
Hello @Cembry and a warm welcome. Stairclimber is one of the exercise shortcuts that is available on your Versa. I recommend using the Exercise App instead of logging your exercise. Check out this Help Article for more information.
Laurie | Maryland
10-27-2019 09:43
10-27-2019 09:43
