Starbucks card not loaded
After using Starbucks on my Versa for 2 years, it now says no card loaded. Removed Versa from app and reloaded. Can’t even find where to load Starbucks card. It’s not listed under compatible apps.
1 REPLY 1
Welcome to the Fitbit Community @SunsetRunner. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing the issue you're having with your Starbucks card. Thank you for your troubleshooting efforts. I would like to advise that the app may take up to 2 min to generate the barcode, so you will see a “No card present on device” while the image is being generated to the device. I recommend making sure you have everything configured in the app settings and wait a few minutes for the card to regenerate. You can confirm the steps to load your Starbucks card into the app here
Upon checking with our Support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, please keep working with them.
