Stats on Versa, how to change order?
My stats on versa watch rearranged themselves now sleep is first want steps first help.
Moderator edit: format
2 REPLIES 2
Tap 'Edit' near top right. Then use drag bar at right to move items up or down.
@Goldenjayne it's great to see you in our Fitbit Community! Regarding the order of your stats, I'd like to follow up and would like to know if you were able to rearrange them after following the steps that shared my friend @JohnnyRow.
If you found his post helpful, please accept it as a solution so other users that have the same question, can find it easier.
As a side note, I'd like to share the Versa's manual so you can learn all its features and get the most out of it.
I'll be around if any question arises! 😀
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
