12-10-2018
04:07
17:37
EdsonFitbit
12-10-2018
04:07
17:37
EdsonFitbit
I left my fitbit versa on charge and then went out to do errands. Came back, checked the fitbit and it showed over 22,000 steps after having sat in charger. This is unsatisfactory performance. Does anyone else have an experience similar to this problem? Any suggestions are greatly appreciated.
Moderator edit: added label
12-10-2018 17:33
12-10-2018 17:33
@Oldsalt66 Tap on the Settings app (little gear cog icon) on your Versa, then scroll down to About. Tap it to open. Your Versa firmware version will be listen on top. For now, you can try rebooting your tracker several times by pressing and holding the left and bottom right buttons until Fitbit logo flashes. If the issue persists, you might have to perform a factory reset in order to upgrade the firmware. In the meantime, you can delete these ghost steps by manually logging activity called Driving for the time period in which Versa recorded ghost steps. You can add Driving activity in the Fitbit mobile app or on Dashboard on Fitbit.com.
12-10-2018 13:45
12-10-2018 13:45
@Oldsalt66 can you please confirm your Versa firmware version. There have been some reports here for older firmware versions. I believe this has been resolved with the update.
Best Answer12-10-2018 16:55
12-10-2018 16:55
Best Answer12-10-2018 17:33
12-10-2018 17:33
12-10-2018 22:42
12-10-2018 22:42
12-12-2018 11:02
12-12-2018 11:02
@Oldsalt66 It's great to see you in our Fitbit Community! I'm so glad to hear that your Versa started to work properly after following the great troubleshooting steps that shared my friend @Marrrmaduke. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community! ![]()
