06-04-2018
21:39
19:16
EdsonFitbit
06-04-2018
21:39
19:16
EdsonFitbit
5350 steps on 5,8 km run !?
Been out running today. The same rute as yesterday. And a got ONLY 5350 steps out of 5,8 km. I measured my step and its not over 80 cm,probebly shorter shorter than that to. And i try to run with short steps:)
Is this correct???
Moderator edit: added label
06-05-2018 11:44
06-05-2018 11:44
Hi there @SunsetRunner, great to have you here in the Fitbit Community as a new member! I saw your step count was too short based on your distance. In this case I saw you have your own stride length. So as a matter of test, try to change to Automatic Stride length and see if the amount of steps improve in future exercise sessions.
If the issue continue, try to perform a restart on your tracker: How do I restart my Fitbit device?
Hope this helps.
06-05-2018 23:22
06-05-2018 23:22
Hi Roberto!
Thanks for answer.
Ok,i just turned off the automatic thing.
I messured my step lenght too get it correct and hoped that would help. (sorry my bad english)
I will se what happends no,maybe i turn on auto again if it doesent work.
Johan
