11-09-2018
		22:50
		09:55
			HeydyF
		11-09-2018
		22:50
		09:55
			HeydyF
My fitbit says undefined for my step count why?
 Best Answer11-12-2018 13:40
11-12-2018 13:40
I did a restart twice and the same, but later on I change the clock face and since than it’s had been ok. Just had some issues with not receiving notes from messenger and when I got a text message but I did a restart again and I did get the text message notation after that. Haven’t got a message on messenger so I have not been able to test that. But step count shows correctly for now.
11-10-2018 06:19
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              11-10-2018 06:19
Hey @VJO, it is great to see new faces around! Let me see if I understood your concern. So your steps are not showed on your Versa, is that right? Or are they not appearing on the app when you sync? Please give me more details so I can help you out better.
I'll be around!
11-10-2018 12:01
11-10-2018 12:01
Hi, yes were the step count would shows on my versa it’s says undif
 Best Answer11-11-2018 00:27
                              11-11-2018 00:27
@VJO could you please take a picture and post it here?
 Best Answer11-12-2018 05:13
11-12-2018 05:13
My versa is doing the same. On the face of my Fitbit where the accumulated steps always show it says undefined. When I swipe up to see the actual details it does list the steps. I have tried restarting it twice. Any tips?
 Best Answer11-12-2018 06:02
11-12-2018 06:02
I’m also having the same problem. On watch face steps feet pic is there but the number is replaced with “Undefined”. Also the little cloud appears with dashes where the heart rate is supposed to show. Has been this way for more than a day now.
 Best Answer11-12-2018 06:46
                              11-12-2018 06:46
Thanks for your response @VJO! A picture of this message, as @Marrrmaduke asked, on your Versa would very helpful for me to further investigate this. But in the meantime, please try to restart your Versa by following these instructions:
I'll be around!
 Best Answer11-12-2018 07:07
11-12-2018 07:07
A little fuzzy but this is what I see!
 Best Answer11-12-2018 08:11
                              11-12-2018 08:11
@Shelbell66 wrote:My versa is doing the same. On the face of my Fitbit where the accumulated steps always show it says undefined. When I swipe up to see the actual details it does list the steps. I have tried restarting it twice. Any tips?
Out of curiosity, have you tried a soft reset (two button press on the Versa) or a Factory Reset (three button press)?
one cruise ship at a time! Best Answer
 Best Answer11-12-2018 09:20 - edited 11-12-2018 09:21
Thanks for posting that picture @Shelbell66! Have you already tried to restart your Versa as I previously suggested? You can also wait until the battery drains out, then recharge it and restart it again.
As @DramaQueenDiva said, a factory reset could also be a solution, just keep in mind that everything on your Versa will be deleted, so you'll have to sync your data and then try the factory reset.
Let me know how it goes!
11-12-2018 13:40
11-12-2018 14:37
11-12-2018 14:37
 Best Answer11-12-2018 14:38
11-12-2018 14:38
 Best Answer11-12-2018 14:40
11-12-2018 14:40
 Best Answer11-12-2018 18:41
11-12-2018 18:41
Different clock face but that's what mine showed as well - undefined steps and no heart rate. I took VJO's advice and changed the clock face and now no problem.
 Best Answer11-13-2018 08:41 - edited 11-13-2018 08:41
 Best Answer11-13-2018 14:29
11-13-2018 14:29
I did both ways to shut down and restart and I am still showing "undefined for my steps etc... what else should I do?
 Best Answer11-13-2018 19:12
                              11-13-2018 19:12
@ThiPhomprida This is probably an issue with the 3rd party clockface you're using. Please install a different clockface on your Versa. In the meantime you can contact developer of the clockface you're using in order to report the bug.
 Best Answer11-14-2018 05:34
                              11-14-2018 05:34
Welcome aboard @ThiPhomprida! Thanks for restarting and shutting down your Versa. As previous users mentioned, and @Marrrmaduke as well, please try to change the clock face you are using, 'cause it seems that the issue is with the clock face itself that you are currently using.
 Best Answer11-17-2018 14:09
11-17-2018 14:09
Clearly lots of different watch faces such as mine are having the same issue so suspect it a a new Fitbit software issue.
