10-23-2022
15:31
14:49
LizzyFitbit
10-23-2022
15:31
14:49
LizzyFitbit
Basically, I posted here but they let me know they don’t want me telling you much info, but check Settings and there is an on/off switch Support should tell you about, make sure it’s on. They would rather you buy a new watch than tell you to check this first. Worked for me!
10-23-2022 18:41
10-23-2022 18:41
Correct. That's no big secret. If you are not getting heart rate, check that you don't have it turned off is Settings, or that it didn't accidentally get turned off.
