04-19-2018 16:51
04-19-2018 16:51
I'm still getting used to the features and apps available with my new Versa, but I did hit upon a question regarding the exercise feature with Fitbit coach. Once you start an exercise session, there seems to be no way to stop it although you can pause. But I thought it odd that I couldn't cancel it and return to my watch face so I had to simply let it run through to the end. Have I missed something?
04-19-2018 17:39 - edited 04-19-2018 17:50
When you hit pause there will be a flag in the upper left corner. Tap that icon and it will ask to end the session
04-19-2018 22:02
04-19-2018 22:02
Thanks, I thought I'd tried everything but apparently not.
04-23-2018 01:56
04-23-2018 01:56
Thanks for this solution - I couldn’t work it out either, until now.
05-12-2018 08:51
05-12-2018 08:51
I see the flag and press it but it does not seem to register that I am pressing the flag. Any ideas?
06-20-2018 10:01
06-20-2018 10:01
Thank you! I was going crazy trying to get out of a run...
07-13-2018 05:08
07-13-2018 05:08
I have the same problem,
see the finish line flag in upper R corner but does not respond to tap or push or hold
can't turn off exercise mode
09-23-2018 13:18
09-23-2018 13:18
Thanks for the response. I had the same problem. Your solution saved me oodles of time.
10-07-2018 14:54
10-07-2018 14:54
Same problem but there is no flag on the pause screen
10-20-2018 18:59
10-20-2018 18:59
Thanks I was going nuts trying to figure it out
11-22-2018 05:00
11-22-2018 05:00
(Charge 3) I also don't see any flags but when pressing the button he shows he paused. Press it again to 'finish'.
11-29-2018 12:17
11-29-2018 12:17
Once I start the exercise session on my fitbit 3 I can't see to stop it. I can pause it. Sometimes I can get it to bring up the finish, seems purely be accident. Help!
11-29-2018 12:17
11-29-2018 12:17
Mine does not register on my fitbit 3 either.
11-29-2018 12:20
11-29-2018 12:20
It tells me to press the button and sometimes it works and sometimes it goes back to the session, continuing to count time. Sometimes it brings up timer/alarms. I hate to go back to my #2 but I might if I can't find a solution that works.
12-27-2018 07:54
12-27-2018 07:54
There’s no flag and it just doesn’t turn off. I’ve pressed the button on the face. Just starts. I’ve pushed button on side and switches between exercise and Screen wake
07-08-2019 07:14
07-08-2019 07:14
I am doing a swim and it won’t stop or pause
08-12-2020 11:24
08-12-2020 11:24
trying to end exercise feature. When I hit pause there is no flag to finish.
12-29-2022 07:00
12-29-2022 07:00
There is no pause button on my Versa 3
