12-28-2019 10:22
12-28-2019 10:22
I'm kind of a medium size strap and Fitbit doesn't make medium straps. The small strap kind of fits me better but I can only put it on the 4 or 3 holes of the small strap. And then with the large straps, I have to use the second or third hole on the strap. So I'm kind of stuck between the two sizes.
Anyone have any advice or anything to do about that?!
With The Charge 2 and Alta HR , I was a large size for the straps. But now with the Versa 2, it's a little different.
I don't want my watch to slide to the side of my wrist.
12-29-2019 06:03
12-29-2019 06:03
Hi @Abbs - I’ve also found sizing to be a challenge on my small wrist. But I was happy to discover that several third party sellers offer woven and metal bands that are infinitely adjustable. They have no holes so you can adjust to any length. Here is one example. Here is another. Hope you find one that works out for you. Personally, I love having several different bands in various colors!
Best Answer12-29-2019 18:04
12-29-2019 18:04
Thanks! I'll have to try those. because it's just really annoying that I'm kind of in between the two sizes. I wish Fitbit made size medium straps.
Maybe some of those third party sellers who make straps will help.
