12-22-2018
03:03
08:06
AlvaroFitbit
12-22-2018
03:03
08:06
AlvaroFitbit
Why i can not see that i am logged in strava on my watch?
Ps. It shows on the mobile app that i am logged in
12-25-2018 08:08
12-25-2018 08:08
@Ausri It's great to see that you've visited the Fitbit Community! Sorry to hear that your Strava app not showing as logged in on the Versa. Try removing the app from the Versa, restart it and then install the app again.
Let me know how it goes!
Best Answer11-13-2019 15:11
11-13-2019 15:11
I have the same problem. Fitbit App says Strava logged, (exercises syncing OK), but app on Versa says I need to link the account.
I've tried the suggestion to uninstall and reinstall but this hasn't worked.
Best Answer11-24-2019 18:10
11-24-2019 18:10
I'm having the same issue and uninstall reinstall did not work.
Best Answer12-16-2019 16:25
12-16-2019 16:25
Restart and reinstall does not work on the Versa 2 - I am having the same issue with the Strava app.
Best Answer12-26-2019 14:25
12-26-2019 14:25
I’m having the same problem as well, not good
Best Answer01-11-2020 23:31
01-11-2020 23:31
Has anyone had an update. I just bought the device today and I can't get Strava or Spotify to login on the Watch
08-24-2020 02:34
08-24-2020 02:34
I'm facing the same issue. I've uninstalled and reinstalled Strava on my Versa. Restarted it at each attempt. I still can't get Strava to work.
Best Answer01-28-2021 15:04
01-28-2021 15:04
I'm having this same issue! Has it been resolved? I've tried uninstalling several times l.
Best Answer02-14-2021 04:36
02-14-2021 04:36
This may help. It worked for me. I'm on a Fitbit Sense.
You have to Go to the device in the Fitbit App, then into the 'apps on the smartwatch' and there you will see strava app. In the settings cog there is an option to log in. This fixed it for me.
Seems there are two separate authorisations. One for the Fitbit app to generally link between recorded data on the app and Strava and then another within the watch app. Hope this helps someone.
Brian
02-14-2021 09:49
02-14-2021 09:49
Restarted and reimstall Strava app still not working om Versa, how long is it going to take to resolve the issue
Best Answer02-15-2021 11:56
02-15-2021 11:56
Did you try the fix i posted above? Defo seems to work
Best Answer02-18-2021 07:54
02-18-2021 07:54
I have a Versa (1). I gave up on the Strava app on the watch and went with the linking to Strava via the website at strava.fitbit.com. I just tried to reinstall the Strava app on my Versa and the app is no longer available to me, presumably no longer supported on the Versa (1).
