Suggestion for saving favorite clock faces on Versa 2
I feel like fitbit should add a favorites feature for watch faces. I might be posting it in the wrong place...but i feel like they should. I literally thought i could remember the watch face i had previously, boy was i wrong. HAHA. im still sitting here scrolling through watch faces trying to find it and write it down, just in case the one i have, Pipboy 3000, ultimately fails me.
1 REPLY 1
Hi there @ogtimchi, thanks for stopping. Thanks for your suggestion about having a feature for saving favorite clock faces on your Versa 2, I'll be glad to help you with that.
Please note that on Versa series and Ionic, you can save up to 5 clock faces to switch between them:
  • When you select a new clock face, it’s automatically saved unless you already have 5 saved clock faces.
    • To save a new clock face when you already have 5 saved clock faces, remove a saved clock face before switching to the new one. If you switch to the new clock face without first removing a saved clock face, you'll see it on your watch, but it won't be added to your saved clock faces.
  • To see your saved clock faces from your watch, open the Clocks apo and swipe to find the clock face you want to use. Tap to select it.
  • To see your saved clock faces in the Fitbit app, tap the Today tab > your profile picture > your device image > Clock Faces. You see your saved clock faces in My Clock Faces
    • To remove a clock face, tap the clock face > Remove Clock Face.
    • To switch to a saved clock face, tap the clock face > Select.
Hope this helps, I'll be around if there's anything else I may do for you.
