08-13-2018 07:56 - edited 08-13-2018 08:17
I have tried swimming with Versa a couple of times in 25 meter pools and it works fine. However, when swimming in a 50 meter pool it is logged as a 25 meter pool. I cannot find a way to fix this. Is it possible to change? Before workout? After?
 Best Answer08-13-2018 12:07
08-13-2018 12:07
Wohoo! I found it: when changing the distance to be correct (in mobile app), the pool length is automatically updated. This was not the case previously so it must be a new feature!
 Best Answer08-13-2018 11:28
08-13-2018 11:28
I just found where to do it in the Versa: From the Exercise -> Swim screen, press the cogwheels and it will give you the alternative. However: can I change it after I have already logged?
08-13-2018 12:07
 Best Answer02-09-2022 05:29
02-09-2022 05:29
Where even is the swimming screen?
02-10-2022 13:26
02-10-2022 13:26
Versa 2 found it - change it in your watch!
