01-02-2019 04:54
01-02-2019 04:54
I am a new fitbit owner, it was given to me as a gift. I also own a lg V30 and when the phone first was set up the two worked perfectly now after a few days of issues, it moved from minor issues to not syncing at all.
Any advice I've tried everything and it's quite frustrating!!!
01-02-2019 06:47
01-02-2019 06:47
Hi, unfortunately your phone is not in the list of supported devices yet, explaining the issues you now encounter. What you can try is this:
1. Deinstall the Fitbit app on your LG.
2. Restart your LG and enable WiFi and BT
3. Reinstall the Fitbit app.
Hope this helps.
01-02-2019 13:58
01-02-2019 13:58
Did all that and it worked for all of 10 mins. Fitbit should be clear on packaging what phones it is compatible with, purchasing was a waste of money and i am pissed
01-02-2019 14:02
01-02-2019 14:02
Hi, for what it's worth, before purchasing a new Fitbit device, check this site: https://help.fitbit.com/articles/en_US/Help_article/2315/?q=compatible&l=en_US&fs=Search&pn=1 . Scroll down to Android Devices and click on it and you will see a list of supported devices.
01-02-2019 14:20
01-02-2019 14:20
@Definitely_dee, don't expect to see the V30 on that list anytime soon. The latest phones they have listed for LG is the G3 and V10, both quite a bit older. I have had limited success with pairing with Versa Classic and making sure all notifications are turned on, even the sub entries. I've had to reconnect once in 2 days because I left my phone out in the living room overnight - about 30 feet away. So far if it's real close it's staying synced. Good luck.
02-27-2019 05:27
02-27-2019 05:27
Brand new Fitbit Versa and it won't sync! When I set it up yesterday when it arrived, it synced and worked fine. Last synced at 9:44pm last night. I've been trying everything to get it to sync. IF IT'S A FITBIT DEVICE, HOW CAN IT NOT SYNC WITH THE FITBIT APP?
02-05-2022 11:23
02-05-2022 11:23
I had same problem. Finally I just set it up on my IPAD instead. Problem fixed. I don't see why I need to buy a new phone when mine works just fine!
02-10-2022 04:57
02-10-2022 04:57
